crAzy95Z28
05-20-2006, 02:53 PM
Can i use this on my car? problem is i have the fuel rail hooked up to the F solenoid and wanted to make sure it wont damage or mess up the solenoid?
please let me know..
thanks
Randy
and btw which kind can i use if i can?
You can use it on your car, however there may be some unique additives that could potentially harm the noid. If you are talking about the small little bottles of cleaner bought off the shelf you should be ok. If you talking about the professional grade that is poured into a bug sprayer, tapped onto the rail and then the car is run off the contents of the cleaner, that stuff is very corrosive and I wouldn't let it get near my noid.
No worries, unless your filling your tank with it :)
