Possible head bore problem?
Old 05-20-2006, 07:30 PM
KingWalrus's Avatar
Default Possible head bore problem?
Ok, so I just purchased some Absolute Speed stage 2.5 5.3L heads from a friend. I knew he had a 370 c.i. motor, but I thought it was just stroked. I just measured the heads, and it appeard that the bores have been machined out to accomodate a 3.925" bore. Would there be any problem mating these heads to my stock bore/stroke bottom end? I'm sure it's not perfectly ideal, but I figured .02" on the diameter probably wouldn't pose a problem.
Your thoughts?
I assume it will still use a stock bore sized head gasket.
Thanks!
Old 05-21-2006, 12:42 PM
KingWalrus's Avatar
Anyone?
Old 05-21-2006, 04:52 PM
xfactor_pitbulls's Avatar
You should be ok. Which valves do they have? Smaller than 2.08 would be best. But even if you have 2.08s it wouldnt be bad.
Brandon
Old 05-22-2006, 02:30 AM
KingWalrus's Avatar
The valves measured in at 2.04/1.60. I really don't think it will pose a problem, but I'm no expert. Anyone else?
Old 05-22-2006, 08:04 AM
PREDATOR-Z's Avatar
No you'll be fine.
Just when you choose the gasket, make sure it is at least .030 bigger that 3.925 bore.
Old 05-22-2006, 11:43 AM
KingWalrus's Avatar
30 thou bigger than 3.925? Why? I'll take your word on it; I'm just trying to learn in the process!
Thanks for the responses, btw.
Old 05-22-2006, 11:58 AM
PREDATOR-Z's Avatar
Beacuse you do not want to shroud your chambers.
Old 05-22-2006, 12:48 PM
KingWalrus's Avatar
Are GM replacement gaskets available in multiple bore sizes, or would I need a cometic or something similar? I have an order placed with Scoggins Dickey on some stock gaskets, but I don't think they've shipped yet. I'll give em a call.
Old 05-22-2006, 01:05 PM
PREDATOR-Z's Avatar
GM 6.0 are 4.060
All LS1 are 3.910 (IIRC)
Old 05-22-2006, 01:26 PM
KingWalrus's Avatar
So it looks like a Cometic is in my future unless the 6.0L gasket would suffice. Now if I could just get a hold of SD! ****, maybe I'll just bore the engine to match the heads. This makes sense...
Old 05-22-2006, 01:34 PM
PREDATOR-Z's Avatar
Max safe bore on stock LS1 block is 3.905
Cometic makes a 3.970 bore
Old 05-22-2006, 01:49 PM
KingWalrus's Avatar
That's interesting. Is that true for all LS1's or just the 97-98 motors? Does going beyond 3.905 require resleeving? I'm kinda surprised GM didn't put more "rebuildability" into the engine.
Old 05-22-2006, 02:16 PM
KingWalrus's Avatar
Ok, just talked to the guys at SD. I got some Cometic gaskets with 3.930" bore and .051" thick. I can't find the stock head gasket thickness anywhere. I swear I remember reading somewhere it being like .036" or so. This gasket is a bit thicker, but it will help with P-V clearance. These heads are milled 10 thou, and I may have them cleaned up with an additional 5 thou taken off.
Thanks for the help!
Old 05-22-2006, 02:29 PM
KingWalrus's Avatar
Found the factory head gasket thickness: .052". These cometic .051" gaskets will have little to no effect on quench, etc. So long as I still have some P-V clearance, I think I'm good to go.
