I need the secret...TTS header removal...
Passenger side came out no prob...Drivers side I'm about ready to cut out...lol
Anyone have any tips on removing the drivers side TTS header?
I removed the oil filter and the drain plug to no avail.
You have to remove the bolt in the motor mount and slightly raise the motor to get it out and in. Put a jack under the oil pan with a piece of wood(so you don't damage oil pan), and raise it up till it slides out. You may also have to drop the bolt on the tranny cross member as well.
I ended up turning the wheels all the way to left, to get the steering knuckle out of the way and I dropped the k frame a litte, then the header came out.
