Motor need a bigger cam, what to do?
Old 05-21-2006, 05:54 AM
BlackZCamaro's Avatar
Default Motor need a bigger cam, what to do?
My mods are listed in the signature. Obviously the cam I have is quite a bit too small to really utilize these heads. Is there any kind of range someone could suggest for them? I know it's a pretty vague question but any guidance would be appreciated. Thanks!
EDIT: Streetability is not a concern.
Old 05-21-2006, 08:33 AM
allngn_c5's Avatar
My car was professionally done by LG Motorsports, and I totally endorse everything Lou sells. If you want a big cam you can go with the G5X3 or the bigger G5X4 also a custom grind could be arranged. Give Bobby or Anthony a call 1-972-429-1963 to find out if you need to flycut your pistons. The X3 is good for 50-70 rwhp over stock in C5 Corvettes and the X4 is even more. X3 is more streetable, X4 is rougher. Tell them that Doug sent ya. Hope this helps.
Old 05-21-2006, 09:39 AM
mrr23's Avatar
http://www.vincihighperformance.com/...%20LS1%202.htm give vinci a call. ask about the 049 or 051
Old 05-21-2006, 09:59 AM
slow trap's Avatar
with 12:3 cr you will be able to use a fairly large camshaft and still have high dcr.you running on 93 octane and have valve reliefs on pistons ?
Old 05-21-2006, 01:22 PM
Thats the thing, we only have 91 in CO for premium, so I have to mix up some 100 octane every tank. And no, the pistons are not flycut.
Old 05-21-2006, 05:57 PM
slow trap's Avatar
no reliefs in the pistons will be your downfall.you have the cr but with a very big cam ptv is an issue.if you have them flycut maybe the ms3 or similar might be what you want.
Old 05-21-2006, 07:39 PM
SVT THIS's Avatar
If you are looking for a big cam I'd look into the G5X3(or4), TRex or MS3. I would notch the pistons anyways to be on the safe side.
