Conversions & Hybrids - Pacesetters width.
OldSchoolFormula
05-22-2006, 05:26 PM
Pacesetters widthI was wondering if anyone could take a quick measurement of their pacesetters from the inside of the flange (head mounting surface) to the outside of the tubes on #68 and #8 cylinders. I need to know if Im going to be able to have them clear between the motor and the 4th gen A/C box in my '73.
Thanks.
OldSchoolFormula
05-25-2006, 04:04 PM
Noones running pacesetters? I thought they were the popular swap header...
67RSCamaroVette
05-25-2006, 09:19 PM
i'll measure tomorrow, if you dont get a reply by then i'll post it up.
olly
79camarols1
05-25-2006, 09:31 PM
If you have 3 to 3.5 in it should fit .
OldSchoolFormula
05-27-2006, 04:42 PM
67RS, did you get a chance to measure them, up?
joelvette
05-28-2006, 12:09 PM
sorry i already modded mine by cutting flush with the outer surface of the head flange and sticking the tubes back in shortening the width your looking for. i did it to increase the clearance down on the subframe,and never had a clearance problem around the a/c box before modding. i'm using brp mounts on my 73 formula as far forward as possible 1/2-3/4 " clearance on the oil pan, about 3-4" to the firewall, pretty close to the a/c box with the valve cover and coils, plenty clear on alt to steering and steering to headers, notched the frame for the a/c. must have had that damn cracked block and tranny in and out 6 or 7 times.
you're going to have to modify the collector on the drivers side to clear the frame, just cut around the collector (but not through the tubes) on 3 sides and straghten it out, then get it rewelded. it really helps having a empty block and tranny for mockup purposes.
67RSCamaroVette
05-28-2006, 03:12 PM
it's about 25" after I modified them.. maybe 2" wider than the heads..
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
