Anyone running 18X10 & 19X11 out there?
I am supposed to get my CCW rims in Wednesday or Thursday this week. I am extremly excited! My 02 Z28 is so pathetic looking with the stock rims.
I bought CCW Sp16A's 18X10 (front) 19X11 (rear) with 275/35/18 (front) and 305/30/19 (rear)
Just wondering of those running a 19X11 in back what tire combo did you go with? Also, did you need to roll the inner quarter lips to keep from rubbing or cutting your tires?
What rear springs are you running? I went with Pro Kit and it seems that those springs are tall enough as the stock rim/tire combo is 25.6" and the 19s should be 26.2ish and there is more then 2"s of gap currently.
Thanks!
Thanks!
19x10's on mine. went with 295/35/19 yoko's even though i could have put the 305/30's on there in pirelli.
did not roll lip, car is lowered with dms, no scraping or rubbing issues.
All four wheels? Any pics?
bone324 i've got 18x9.5 on front....jeffstar asked for rears only.
jeffstar, 27"s to bottom of quarter panel. i've also got a 12 bolt moser. someone said that raises rearend a tad bit also compared to stock. not sure if that's true or not though.
from ground to top of tire was between 26.2 and 26.4
hope that helps
rob
hope that helps
rob
