Is this normal (AC changes from dash to floor vents under mild acceleration)
I've seen the option in EFILive to disable the AC at a given RPM/TPS setting, but I didn't see one that really matches what I'm seeing.
Occasionally, under mild acceleration (30-50% throttle) my A/C will divert from the dash vents to the floor vents for a few seconds, even though I'm set to "Max AC". It's not a big deal if it's supposed to work that way - but if it's a symptom of something else bad then I'd prefer to fix it.
how do you fix this problem, not to hijack the thread but maybe he has the same problems but mine when i turn it to just heat or whatever i have to go all the way over to defrost then wait a min and turn to like the foward arrow or so on it willl then start blowing or sometime i can just turn it to the foward arrow and take off down the road and ina lil while it will start bloweing like normal?????
Anyone have a clue as to how to troubleshoot this?
This is the only wierdness I've got with the climate control (so far) - I don't think I'm getting the same thing you're getting, CULATR.
