When is it necessary to replace intake manifold gaskets
Just curious if I should replace my gaskets on the manifold or not. I've had it off a few times and have never changed them. Doing a build up and need some gaskets and didn't know whether I needed to spend the $50 for the gaskets.
Re: When is it necessary to replace intake manifold gaskets
Since you have had it off a bunch you may want to replace them for peace of mind but everything I've seen and read says you can re-use them over and over as long as they stay intact.
