Fueling & Injection - ?? on injectors and fuel pump
View Full Version : ?? on injectors and fuel pump
1999TransamWs6
05-22-2006, 10:25 PM
looking to make between 500-600 RWHP on motor and another 300-400 on spray what type of fuel (12:1-13:1 CR) And what injectors and pump should I use. (I will have a stand alone for the nitrous). I have a 255 racetronix pump and 42 #'s Should I go bigger????? What do you guys think?
Nasty N8
05-23-2006, 01:06 AM
Your pump and injectors should be suficent for your motor hp and with that CR you will need to run 100 octane.
Nate
JMBLOWNWS6
05-23-2006, 05:06 AM
Or you can run a mix of what ever octane is available to you and mix it with motorsport 109 by vp. Thats what I do. :) The 42's should be fine.
1999TransamWs6
05-23-2006, 07:14 AM
Thanks guys I guess ill leave them in and check the duty cycle.
