what cam with my combo
me and my friend are building up his motor
its a stock forged 346
patriot stage 2 6.0 heads 64cc
long tubes
ls6 intake
36 pound injectors
ported throttle body
auto with 3200 stall
now my question is what cam would be best for this combination smog does not matter and input would be appreciated
long tubes
ls6 intake
36 pound injectors
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well, I am not going to be the only one to suggest this to you.....search a little more.
But since you ask I will try my best.
What is the car's primary use?
Daily Driven?
Strip/ Steet/ Auto-X
230/236 - 224/224 - 226/232
And what is a "stock forged" motor? Unless you mean stock cubes.
Daily Driven?
I was thinkin a f13 but he wants other peoples opinions on what fits his stall and he wants it to operate up to around 6400rpm's it doesnt really matter no higher then 7k
OK im "The Friend"
Basically, i want the max performance-But still the driveability of an everyday car if i needed it to be.
Im just haveing a hard time matching the heads and stall to a proper size cam
thanks guys
thanks guys
Just got off the phone with a tech from SPDC2000
Let me get your guys .02
He recommended a cam called N228
here are the specs
228/236 114 LSA Lift on the intake side 551 and the a 600 in the exhaust
so, watcha guys think?
here are the specs
here are the specs
here are the specs
If you insist on running such a large exhaust lobe, then you could increase the duration on your intake side to not be so heavily exhaust biased. This would allow you more RPM range and theoretically more power potential.
I also wouldn't buy a 114 LSA cam, but that's just me. If I was concerned with overlap, I would just opt for smaller lobes ground closer together.
FWIW, that intake lobe appears to be a little "lazy". I would consider more aggresive profiles.
Ben T.
Originally Posted by Studytime
I think it's going to make okay power, but i would not run an exhaust lobe that big unless you plan to spray a 200 shot. I drive my car on the street a lot, and I like to use as much of my power stroke as possible. I wouldn't want my exhaust valve opening so early (236 lobe), needlessly bleeding off pressure too early before bottom dead center.
Ben T.
Ben T.
ok sounds good, thanks for the input. Any other ideas on what cam then?
Ben T.
I know you're not asking me again, but I still vote for the 230/224.
Ben T.
Ben T.
