6.0 iron block parts list..
I am not worried about heads,cam,intake or pistons,rods,crank,main studs ,bearings or head studs or head gaskets..
But need part numbers for the rest of the setup to put one of these in my 99 ta.
Likley go with just buying a new block from gm rather than a wrecker motor.
I will be selling off my ls1 engine mostly complete.
So assume I need oil pan,oil pump,timing chain,water pump,not exactly sure what else..
Actual part numbers would be great.
If you look around on here you will probably find what you are looking for.
http://www.sallee-chevrolet.com/fram...n_3/index.html
You may also wanna try the search feature on the site.
