02 b1 stays at 447mv with LC1 hooked up
You can try to set the high/low output of the narrowband sim (using LM Programmer) to the same number to force the analog output to a certain value. Example- Set high/low both to .75 to see what you are reading. Also try and read the O2 using Logworks Serail interface.
Sounds like you may not have it wired right, or worse case, you blew the analog output for that channel.
Sounds like me. I had a wire wrong. Was sending the signal up the wrong 5v wire.
Nothing bust, its easy to do as one was 4.5v the other 4.8v so figuring out which one was signal and signal/ground or whatever it was called was a bit tricky.
Are you talking about the A and B pin on the O2 connector was wrong?
It reads 20.8.
It reads 20.8.
One output reads .75 and the other reads 4.26.
Does this mean that the 4.26 output is blown?
How are you reading your outputs (HPT, mutlimeter, Logworks, etc.)? It sounds like your WB output is the one that isn't working. If so, try reading it via the serial cable in Logworks. This will eliminate grounding errors on the reading instrument and also the DAC, as Logworks reads the signal before it gets converted to an analog output.
Normally .447V is what efilive logs when monitoring a disconnected stock O2. If you have the stock O2 disconnected on B1 it will give you that voltage. You need to setup a pid and possibly a map also to monitor the WBO2 output. The WBO2 should be a voltage 0 to 5 volts depending on AFR. Check and make sure you have the proper analog output selected (there are 2 normally), double check wiring, and setup the proper pids depending on your tuning software. Hope that helps.
Dave
Dave
