what oil pump
Old 05-23-2006, 07:14 PM
artic's Avatar
Default what oil pump
Building a 355 with srp piston and stock internal, what oil pump should i run . have been told no to run a HV????
Old 05-23-2006, 07:32 PM
96capricemgr's Avatar
People are WAY too fast to ASSume the stock or stock equivalent pump is weak or inadequate.
Old 05-23-2006, 07:48 PM
artic's Avatar
its a question if you dont have a answer then dont reply
Old 05-23-2006, 08:11 PM
383LT1S10's Avatar
*sigh*...we've been through this before. Yes a stock pump will perform well enough for your engine. HOWEVER, a decent aftermarket hi volume (not high pressure) will also perform very well. This is just like cam threads and everyone has their own views. I myself use Melling Hi Volume pumps on most engines I build. Though when i build my stroker I am looking at the Moroso pump.
Old 05-23-2006, 08:22 PM
That answer was stock or stock equivalent is all you need, a LITTLE ability to think might have revealed that riddle to you.
A HV pump will put more strain on the drive, the PLASTIC drive, and some guys have had them pump the pan dry if you use a stock pan and sustain high rpms like road racing. Two risks that while not great are catastrophic if you are the one they happen too. IF you decide against my advise to not "upgrade" please at least upgrade the pan.
Old 05-23-2006, 08:27 PM
383LT1S10's Avatar
Yes, i should have mentioned using the melling steel renforced driveshaft for the pump. A whopping extra $5.00. Hi volume pumps COULD suck a pan dry though the odds are less than slim. If hivolume pumps were such a "threat" they wouldn't be used as widely as they are.
Old 05-23-2006, 08:29 PM
Rare96WS6's Avatar
I use the stock pump after doing the 355ci. I have had no problems. I do not road race the car, just 1/4 mile it a few times a year. The pump now has 64k miles on it.
Old 05-23-2006, 08:42 PM
streetwarrior96's Avatar
I use melling HV
Old 05-23-2006, 09:54 PM
The driveshaft is a good point but I was replying to the dummy distributor stub that links the oilpump to the cam. I have seen guys who "upgraded" pumps start having problems with that.
Old 05-23-2006, 10:38 PM
383LT1S10's Avatar
i can see where that might be an issue on an LT engine since they have the dummy shaft (yet another thing I am glad to be rid of). Anything with a distributer will have no issue with a HV pump wear wise unless they try running straight 50 weight in sub zero temps. lol
Old 05-23-2006, 11:33 PM
Ls1Bait's Avatar
Canton 6-quart oil pan
Melling high volume pump
Canton pickup (bolts on so it can't come off after pressing it on)
And a metal shaft connection
Old 05-24-2006, 09:02 AM
That's MISTER MODERATOR
Paul Bell's Avatar
I would use a stock big block pump from Mellings or Moroso with the anti cavatiation grooves milled into the cap.
Quick Reply: what oil pump
