Granatelli MAF
Re: Granatelli MAF
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by zTrackerz:
<strong> I ordered a Granatelli MAF today. Are these any good?????? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I've had one for well over a year now and really like mine. I picked up ~8RWHP and maintained a perfect 13:1 Air/Fuel Ratio on the wideband. Quality product. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Mike
Mike
BMW ///M Nerd
Re: Granatelli MAF
I ordered one recently. I'm not sure if the one I got is a granatelli though. The package I got from ls1 motorsports came with a lid filter and was supposed to come with an SLP maf. They told my dad that they had run out of the slps for xmas and were including a Granatelli one instead. on the invoice it says its a granatelli, but says DELPHI on the top connector piece. Is this really a granatelli one or stock piece? Thanks If you can help.
-Rob
-Rob
Re: Granatelli MAF
I am very happy with my Granatelli - not only does it pull stronger through the range, it runs noticeably smoother through the RPM band. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Re: Granatelli MAF
Thanks for the input guys.... And about that SLP MAF, I don't know if they would substitute A granatelli. The SLP is like $149.00 the Granatelli is like $320.00...
BMW ///M Nerd
Re: Granatelli MAF
Yeah but they did. I have it all figured out now. It is a granatelli MAF. The reason it says DELPHI on it is because Granatelli buys the MAF from GM(or the like) and recalibrates it for the f-body(85mm). I got lucky when they replaced the SLP with the Granatelli, it's actually what I wanted in the first place, but didn't want to pay the extra $$$.
Re: Granatelli MAF
I've got a GMS MAF for sale if anyones interested. Used 1 week $175.00, send me an e-mail.
BigBlackZ28,
Tranny line pressure has nothing to do with the MAF. The line pressure should be set to follow the throttle position sensor.
BigBlackZ28,
Re: Granatelli MAF
they can be beneficial depending on wether or not your car is an a4 or an m6. if an m6 and you want to cough up the bucks for it they are seemingly better than just maf ends.
however in an a4 they can bump transmission line pressure because under load which usually means much increased throttle position, the maf flow rate is calibrated to adjust accordingly with the throttle position. thus if flowing more air through the larger diameter then pressure will rise unless tuned for the added flow in which case its just another bolt on for yet another bolt on buck.
Re: Granatelli MAF
I just installed a Granatelli MAF today... I kind of like it. Price wise the are fairly expencive, but I did see a noticiable difference.
Re: Granatelli MAF
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MIGHTYMOUSE:
<strong> your line pressure will drop with a ported or uncalibrated 85mm meter. if it went up, that would be no problem. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">since the granatelli units are calibrated, we have nothing to worry about right?
