Which wire goes to fuel pump?
Old 01-18-2003, 10:29 PM
LS1Tech Sponsor
Slowhawk's Avatar
Default Which wire goes to fuel pump?
2002 Z28.
Looking for which color wire goes to the fuel pump at the plug over the axle.
Thanks
Slowhawk is offline
Old 01-20-2003, 07:46 AM
Ken G's Avatar
Default Re: Which wire goes to fuel pump?
I believe the gray wire is the power wire to the pump coming from the relay. Maybe someone can confirm this.
-Ken
Ken G is offline
Old 01-20-2003, 08:29 PM
wrencher
wrencher's Avatar
Yes the grey wire is correct.
wrencher is offline
Old 01-20-2003, 10:10 PM
LS1Tech Sponsor
Slowhawk's Avatar
From what I found tonight it was the white wire that powered the pump.This was the harness from the bulk to the pump.So I'm figuring that the gray wire that everyone is saying is the wire before the bulkhead connector?I put a voltage meter on the 2 grays in the harness and one read 5v and the other 0 volts when starting the car.The white wire would read 12v for a second when key is turned to run.Then when I started the car it had the battery voltage on it.When I cut the wire the car would not run due to no fuel.
Slowhawk is offline
Old 01-21-2003, 08:28 PM
Ken G's Avatar
I'm not sure about the wire color after the rear seat relay. When I wired my Walbro in-line pump I powered it from the aux. positive post near the fuse boxes in the engine compartment. I used a 30 amp relay with a 20 amp fuse and triggered the relay off the gray fuel pump power wire coming out of the fuse box. Many people told me not to try to power the pump off of the small factory power wire (too much voltage drop). You might want to check out Vortec's T-rex instructions using this link (starts on page 14):
http://www.vortechsuperchargers.com/...s/4gk218im.pdf
-Ken
Ken G is offline
Old 01-21-2003, 09:55 PM
LS1Tech Sponsor
Slowhawk's Avatar
I actually just needed that wire to power a relay.I ran a 10 gauge wire back to power a Kenne Bell boost a pump.The stock pump feed switches the relay to power the pump,then when we spray the nitrous another relay kicks in and adds the extra voltage that we set.
Slowhawk is offline
Quick Reply: Which wire goes to fuel pump?
