throttle body question?
can you remove the 2 coolant hard lines that attach to the throttle body? did the tb bypass mod, and don't like the look of the caps on the tubes under the tb. just wondering.
Originally Posted by RrCoX22
a little confused on the question... you need to either have the caps on or the ports tubed over, whats wrong with having the caps on?
Just pull em out, no need to plug em off anyway. Ive even cut the line boss down smooth for a couple of guys. Its just an in and out on the coolant on the bottom, you do the bypass- no need for em anymore.
