HP Tuners 98 2 Bar Knock vs RPM PE
Old 05-25-2006, 12:36 AM
MECHAM's Avatar
Default HP Tuners 98 2 Bar Knock vs RPM PE
after converting the old non 2 bar to the new 2 bar setup. the ecu registers max knock when I go WOT...only when I hit Knock vs RPM PE mode. the original values were 4..and i would get 4 degrees of knock throughout the whole powerband. so i changed the number to 5 and i got 5 degrees of knock.
using the cobalt 2 bar MAP...
converted the file according to this...
http://www.hptuners.com/help/demos/2%20bar%20sd.swf
any1 know why this is now?
