View Poll Results: what next
Ls1 Aluminum Drive Shaft
50.00%
TA rearend cover
8.33%
A bottle heater for my Nitrous Kit (not listed in sig yet)
25.00%
A purge kit (nitrous not in sig)
16.67%
Voters: 12. You may not vote on this poll
What mod Next?
Old 05-25-2006, 10:08 AM
edlt1's Avatar
Default What mod Next?
I am really not sure what to do next? Help me out here.
what whould you do. Everything done so far is in the sig.
Old 05-25-2006, 10:11 AM
Hot94Z28's Avatar
Stall is what I would do next since its a A4
Old 05-25-2006, 10:12 AM
edlt1's Avatar
3000 or 3200
Vigilanti or fuddle
Old 05-25-2006, 10:14 AM
Ryan34's Avatar
Do you not have a Cold Air Intake? I mean your sig says k&n filter, so i'm assuming thats just the stock filter? I would do that next, if it were me. But out of the ones listed i picked the drive shaft...but thats because i don't know what the nirtrous heater thing is for
Old 05-25-2006, 10:16 AM
edlt1's Avatar
ws6, stock Ram Air
Old 05-25-2006, 10:18 AM
edlt1's Avatar
THe nitrous heater is to keep the bottle pressure where you want it.
I live in michigan. Someone told me I may even need it in summer
Old 05-25-2006, 10:20 AM
Hot94Z28's Avatar
I still say stall would help you make the most use of the mods you have right know and even future ones
Old 05-25-2006, 10:22 AM
OneFast97Z's Avatar
WS6's have the stock ram air design... the k&n filter and smooth bellow are about the only upgrade you can do as far as cai goes.... The nitrous bottle heater heats up which creates more pressure inside the bottle
Old 05-25-2006, 10:27 AM
edlt1's Avatar
onefast97z where did you hook up your electric water pump?
when does it run, when the motor is running or when the key is in the on position?
Thanks
Ed
Old 05-25-2006, 10:43 AM
OneFast97Z's Avatar
I hooked up my electric water pump to a fused ignition-on lead... so yes, the pump turns on when i turn the key to the on position.... however... i also added my own little twist... I ran to radioshack with a couple bucks and soldered up my own simple 555 timer circuit... Now, whenever i turn off my car, the waterpump will keep running for 1 to 10 minutes before shutting off.... depending on how long i set it for... i did this so that it will cool down my engine between runs quicker, and because i always forget to turn things off, and i really didnt wanna kill my waterpump or battery...
Old 05-25-2006, 10:54 AM
lt197formula's Avatar
definatly a 3200ish stall
Old 05-25-2006, 11:34 AM
edlt1's Avatar
Yeah that would be sweet. Is there any way I can rig it up so that I can turn it on with a manual fan switch? so I can have my fans and pump running.when I want them too?
Old 05-25-2006, 11:44 AM
OneFast97Z's Avatar
Yes, and thats simple... you just dont want to forget to turn them on...
Old 05-25-2006, 01:29 PM
Ryan34's Avatar
I knew that!!!! I just didn't see it, lol i'm a
Old 05-26-2006, 10:49 AM
sssalah's Avatar
None of the above, stall is what I'll do.
Old 05-26-2006, 11:14 AM
OneFast97Z's Avatar
Actually, since i didnt realize that i never gave my opinion on what you should get next, ill tell you that i would go all suspension...
Old 05-26-2006, 12:23 PM
imnotplutonium's Avatar
i voted for rear-end girdle. its always good to be safe . also did you guys get a noticable difference with your waterpump? and do those last as long as say the stock one?
Old 05-26-2006, 01:34 PM
blind527's Avatar
Stall stall stall stall stall!!!!!!! Say hello to .4-.7 drops in your ET's depending on traction!
Old 05-26-2006, 03:45 PM
OneFast97Z's Avatar
Exactly... cant go anywhere if you dont have traction... get SUSPENSION!
Old 06-26-2006, 02:14 PM
97blkz's Avatar
x's 10000000000000000000000000000000000000000
Quick Reply: What mod Next?
