PCM Diagnostics & Tuning - Catalyst code.
View Full Version : Catalyst code.
BlueSS346
05-25-2006, 02:05 PM
My check engine light came on so I used an Autozone scan tool. It came up with two codes that both read the same, it said "catalyst below threshold bank 1."
The guy at the store said their tool can be a little vague and it could either be an oxygen sensor or a cat. Anybody have this same code before?
slow
05-25-2006, 02:49 PM
P0420 and P0430?
Ryan
Florian
05-25-2006, 02:59 PM
sounds like P0420, has to do with your cats and the hydrocarbons/emissions
F
2001NBMZ28
05-25-2006, 06:45 PM
P0420 is most likely a bad drivers side cat. Cats are covered under the federal emissions warranty for 8yrs/80K. To doublecheck you can swap the rear 02's side to side and see if the code moves.
BlueSS346
05-25-2006, 08:58 PM
I will have to go back and get the exact numbers. If it is a cat I doubt the dealer will replace it, I know they will blame my nitrous. Thanks for the input.
98Grnz28
05-26-2006, 06:14 PM
Nitrous Kills cats!!
BlueSS346
06-02-2006, 02:28 PM
Ok, here is the exact reading. "P0420 Catalyst efficiency below threshold bank 1" This code came up twice. So if this is a bad cat then it's a total excuse to get a set of long tubes and highflow cats.
SSpdDmon
06-02-2006, 02:39 PM
Don't jump to conclusions Blue...it could be an O2. Read above...
spincksten
06-03-2006, 10:52 AM
i have the same exact code showing up on my car right now. where are the rear o2's located?
lgobraves
06-03-2006, 03:37 PM
after the cats
BlackHawk T/A
06-03-2006, 08:02 PM
Happened to me right before I pulled them off to run my X-Pipe and my Longtubes...
It's normal, they don't last forever. Mine did it at 73k miles.
spincksten
06-06-2006, 05:45 PM
so if i gutted my cats and put 02 simulators on, would that pretty much solve the problem.
