Comp Cams "Cam Help Call Line" what a Joke!!!
Called Comp Cams “Cam Help Line” today about XFI and LSK lobes.
He stated that the “LSK was a solid roller application only and that anybody using that lobe with hydraulic roller lifts WILL break, if not today very soon”
Secondly the XFI lobe numbers I asked about he stated the lifts to me with a 1.7 rocker were completely different than the Comp Camps catalog states. He got pissed off that I questioned the lift numbers. There was not anyway he could have been less helpful or more of a complete jerk. The phrase “Comp Cams Cam Help” was completely laughable.
If Comp Cams ever reads this PM me and we can talk about this at length.
Do you have "gears and a converter sir"? That type of question.
I don't think you can talk to their "good techs" by simply dialing a 800-number.
Good luck,
Ben T.
Apparently they have more cam lobes than what is "listed". I called last week and the Tech gave me numbers for a cam lobe that I couldn't find listed anywhere. Being the skeptic that I am, I called back the next day, spoke with a different Rep, gave him the lobe number and he verified that it was good. He then gave me the same specs the guy had given me the day before. I learned that just because a lobe isn't listed, doesn't mean it doesn't exist.
Your experience must have been frustrating to say the least. Sorry to hear about it. BTW, did you give them a second chance? IMHO, everyone deserves one of those.
My calls to Comp Cams Help have produced excellant results. I have called several times, spoken to different reps and found them to be knowledgeable, helpful and friendly. No, I'm not a noob to cams. I do know the difference between ICL and LSA. I am not, however, a guru either. That's just my experience. HTH
You are right. I have had a chance to cool down. The person I spoke with was plain to see he was instructed to ask my application to input into some formula to make a recommendation on cams they stock. He was completely lost when I told him I wanted to run at a certain DCR. He told me they never look at that to select a cam shaft. I told him that I was thinking about 110 LSA and his responses was “What the hell for?”
He had no knowledge to be able to discuss the pros and cons between lobe profiles. I was the idiot for even bring up LSK lobes.
My bad for not getting his name. I might try calling again or trying their local number to find someone who can possibly help.
I am not one of most knowledgeable on the subject and that’s a fact, but not a complete dumb *** either.
I sold my TR224 114 LSA a couple of weeks ago to someone on this forum. I like J-rods statement about not being a lazy F*ck and do my home work to find the best grind for my particular setup. I real like the idea of a custom grind to get it as close as possible. I think Patrick G. has done a great job in leading the way.
I called the help line to ask for a replacement cam card and some very basic tech info. I was treated like absolute dog ****. It was obvious to me that if it weren't for their superior product, a company that treats their customers like they did me would go out of business in a very big hurry.
