AFR readings on gauge different from EFILive logs....
High on diesel fumes
I have noticed recently that my DynoTune WB AFR gauge is reading two or three tenths higher than EFILive. Any ideas on why? It just happened recently, used to be pretty much spot on. My grounds for the EFILive connection and the gauge are run to the same place.
Originally Posted by Black02SS
I would try to recalibrate the sensor. It could also be that your sensor is going bad and needs repalced.
I'll try it, I hope the sensor isn't going bad I've only had it installed for about 2 months. I thought about the calibration thing too, but it's like the analog outputs are each reading differently. Weird.
Oh, forgot to post that it's an Innovate LC-1
Originally Posted by Phil99vette
Its a ground offset difference. I'd log the WB with their software and use HPT and average the numbers and create a new pid.
Phil
Phil
Compare the value you get in EFILive to Logworks and then come up with your own calibrated pid so that EFILive matches Logoworks. If you have any problems Black02SS can help you out. He helped me calibrate my LC1 and it is within a couple hundredths of Logworks. Black02SS is the man when it comes to Innovate widebands and EFILive.
Finally got around to hooking up LogWorks, and it matched my gauge almost exactly. Confirmed that the calculated EFI PID was reading about .2 richer than the actual AFR. I went in to the sae_generic.txt file and changed the default calculation for the LC1, it now reads "({EXT.AD1}*3)+7.55" instead of "({EXT.AD1}*3)+7.35", and it seems to match up almost perfectly. Thanks for the help guys.
