Low A/F BLM's....What are the possible causes?
Old 05-26-2006, 02:51 PM
wrd1972's Avatar
Default Low A/F BLM's....What are the possible causes?
Logging data shows low load BLM's under 110, medium load around 115 and high load seems to be normal.
What are all the possible cause for these low BLM's?
Old 05-26-2006, 05:00 PM
TwoFast4Lv's Avatar
which injectors are you using?
Old 05-26-2006, 05:11 PM
blkchevyz's Avatar
that and are you running an adjustable regulator.
110 means its rich... 108 is maxed out... if i remember correctly.
Old 05-26-2006, 05:27 PM
TwoFast4Lv's Avatar
Exactly
Old 05-26-2006, 07:44 PM
RedRyder518's Avatar
Check your fuel pressure. My adjusable FPR got set to 65 PSI somehow and I was running at 108 BLMs. Set it back to 43.5 PSI and now they are in the mid 120s.
Old 05-26-2006, 08:01 PM
wrd1972's Avatar
I am running stock injectors and stock FPR, no mods to fuel system. It dynoed rich last time too so this is not a surprise. The car has always seemed to run rich. Last year the plugs fouled so bad it would not start plus I get the black spray out of the exhaust from time to time.
With my mods do I need the new injectors and a FPR?
What should my stock setup pressure be.
Thanks
Old 05-26-2006, 09:08 PM
TwoFast4Lv's Avatar
I would take a look at the injector constant in the PCM and see if some one has fudged it or the MAF tables even
Old 05-27-2006, 08:27 AM
wrd1972's Avatar
Is there a way to do thist with Datamaster or Freescan.?
How do I do this?
Old 05-27-2006, 12:52 PM
buffman's Avatar
Get Tuner Cat
Quick Reply: Low A/F BLM's....What are the possible causes?
