18x8.5 & 18x9.5 staggered, is 35mm offset going to cause a problem?
Old 05-26-2006, 06:10 PM
Asmodeus's Avatar
Default 18x8.5 & 18x9.5 staggered, is 35mm offset going to cause a problem?
Would run 255/275 front/rear. Will this be too close to the lip? I'm also liely going to drop it about an inch. Will I need to roll the lip at all?
The rim is an ADR M Sport chrome.
http://www.adrwheels.com/wheels/?sfID1=12&sfID2=163
Old 05-27-2006, 12:59 AM
Asmodeus's Avatar
someone has got to know this...
Old 05-27-2006, 02:14 PM
YngBird's Avatar
i have the same wheels but in black with a polished lip.same size.i run bfgs in front and back.275/40 18 in the rear no problems.i also run a 245/45 in the front and it rubs just a little.i think if you went with a 245/35 youll be better off.i'll post pics if you'd like.i think my car sits almost perfect.it needs a half inch drop in the back.
