Drag Racing Tech - Mounting engine to BMR k-member
SiL3NtXWS6
05-27-2006, 12:24 PM
How are you guys mounting your motors to the BMR k-member?
This will be using mounts and not plates.. i am just kinda confused on what to do. I wanted to do solid mounts on my stock k-member, but my kooks won't clear the stock one ( 2 inch)
theblur98ss
05-27-2006, 12:29 PM
It should mount the same as stock using either their mounts on the k member or a seperate set of mounts.
SiL3NtXWS6
05-27-2006, 12:31 PM
I'd like to use a solid mount setup with the k-member but i'm not sure how i'd go about doing that..
ALL UC2
05-27-2006, 03:06 PM
do a search on post from sux2bu he made his own solid mounts. looks like a good design.
theblur98ss
05-27-2006, 04:16 PM
Do you have the bmr k member without motor mounts? If you're using solid mounts you need to order the one without mounts.
SiL3NtXWS6
05-28-2006, 03:23 AM
alright.. say i wanted to go with poly mounts, which do i get?
The Juggernaut
05-28-2006, 08:09 AM
Thunder racing has the poly mounts.They can be a real PITA to put in, but work good.
JMBLOWNWS6
05-28-2006, 08:13 AM
Summit has the best prices. Those prices are crazy from Thunder for those poly mounts. Your going to have to grind off the rivets and drill out the holes. Mine were like $50.00 plus shipping.
SiL3NtXWS6
05-28-2006, 11:15 AM
well fuck, what motor mounts are a bolt in style for this k-member?
theblur98ss
05-28-2006, 12:06 PM
BMR makes 2 differant k members. One with motor mount provisions and one without. We need to know which you have and we can go from there.
SiL3NtXWS6
05-28-2006, 12:23 PM
I have the one with the motor mount provisions
theblur98ss
05-28-2006, 11:29 PM
Poly mounts are about your only option then.
FastBlackTA
05-29-2006, 08:25 AM
I bought my ply mounts from Billingsley. All you have to do is drill out the rivets, get the old rubber mount out, then install the new poly one using bolts. They seem to work great (motor will not move at idle or stalling the car up) - no track experience quite yet but we'll be testing them soon.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
