WTB: Ram Air Trans Am 93-02
Hey guys I'm looking for a Ram Air Trans Am between 93-02 with less than 50,000 miles with ttops.. Im also looking to spend under $9,000. Anyone have anything?
I just responded to your pm. I wasn't trying to insult your thread, but that's a pretty high demand. I will show you my car even though it has 83,000 miles. It is for sale for $9200 firm. It is a 6 speed, t-tops, and immaculate. No engine mods, only k and n and magnaflow catback. You can see most of the mods in the pics, but let me know if you're interested and I will give you all the details you want to know.
Red 99 WS6 for sale
I have a 99 Red WS6 Trans Am with a A4 for sale. Car has the 12 way power driver seat with light interior. Paint is in good shape and car has 4 new tires (~1000 miles on them)
Engine is stock other than lifters and valve springs and has ~42000 miles.
Mods:
Transmission is a FLP stage 4 4l60e with 3200 stall vigilante converter that have ~16000 miles on them. The stock transmission and torque converter come with the car and work perfectly.
Chromoly PA K-member and a-arms
SLP bolt on diamond subframe connectors
Stainless steel brake lines upfront
BMR adjustable panhard rod, boxed lower control arms, control arm relocation brackets, non-adjustable torque arm and driveshaft loop
TA aluminum differential support
Hal QA1 adjustable drag shocks all four corners with front drag springs 275lb spring rate. All four shocks were rebuilt about ~2000 miles ago and revalved to R-series specifications. I still have the stock front springs and spring perches. The stock rear springs are still installed.
Car also comes with LS1_edit and autotap for programming and scanning. Currently a whisper air lid is installed but stock WS6 air box is available.
Car has stock exhaust manifolds/cats and a hooker aerochamber cat back.
I am looking for $10000. Probably missed a few things. Car is located in Las Cruces, NM (southern NM).
Gary
Mods:
Gary
