Quick A.I.R. System Q?
I did a search but couldn't find what I was looking for. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
When removing the A.I.R. system, are you suppose to unplug both the electrical plugs? What is the little one for(just curious)?
Thanks!
Thanks!
Re: Quick A.I.R. System Q?
i only remember one plug on mine. the one at the pump. the only other thing was the vaccum line <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
T is for Towing not Turbo
So what exactly is that little pump? Is that the high pitched pump you can hear after you start your car up and are standing outside it? And what does it do? Thanks. <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
There is a plug, up by the pump itself. And there is a smaller one (with 2 wires) kinda below the pump. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
<small>[ February 03, 2003, 08:54 AM: Message edited by: MOBE ]</small>
Below the pump? You're talking about the AIR pump in the fender right? There should be a plug going straight into the pump. I'm lost with the "by the pump" and "above the pump" talk, it goes right into it.
I removed mine from my C5 while fixing the rock damage I had and it was only one plug.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by silverbullet02:
<strong> So what exactly is that little pump? Is that the high pitched pump you can hear after you start your car up and are standing outside it? And what does it do? Thanks. <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">yep, thats the one. it pumps fresh air into your cats at start up to help light them off.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by jmX:
<strong> Below the pump? You're talking about the AIR pump in the fender right? There should be a plug going straight into the pump. I'm lost with the "by the pump" and "above the pump" talk, it goes right into it.
I removed mine from my C5 while fixing the rock damage I had and it was only one plug. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, I'm talking about the AIR pump in the fender. There are 2 plug harnesses in there! One that is BY the pump (that goes into it), and 1 smaller one (2 wires) that is in the "mess" of conveluted tubing BELOW the pump. Just curious as to what the small one is for.
Anyone?...Anyone?...Beuller? <img border="0" alt="[boring]" title="" src="graemlins/gr_zzz.gif" /> <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by WILWAXU:
<strong> hmm.. if I remember right.. it all comes out as one piece attached to the same frame. I chalked it up to being part of the pump setup. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ok, cool!
I pretty much fugured it was part of the system, but wasn't sure what it was for exactly. I have removed the check valves and tubing, but left the pump on for now. I may end up using it in place of the pcv, like some are doing.
Thanks! <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
<small>[ February 03, 2003, 09:13 PM: Message edited by: MOBE ]</small>
FWIW, I ripped mine out the other night and there were two plugs. All of the hoses and lines ran into the same place but there were two plugs. Must be ok...no codes yet! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
