Quick Question in middle of valve spring swap
Old 05-28-2006, 07:43 PM
sh33p4u's Avatar
Default Quick Question in middle of valve spring swap
I have the patriot gold dual valve springs. The seals that came with it all look the same? Is there supposed to be a different one for the exhaust and intake like it says on LS1howto.com ? Thanks in advance!
Old 05-28-2006, 07:58 PM
chewy99ws6's Avatar
the seal that comes with the kit, I want to say is the intake,I am not sure, I know it is the top seal when you pull the springs off, replace the top seal with the PP new seal. I put the same ones on and that is all I did.
Old 05-28-2006, 08:21 PM
john59's Avatar
There all exhaust seals. Just went through the same thing installing PRC Springs on my Darts. Gunner from Patriot hooked me up. You will have no problem using those seals.
Old 05-29-2006, 09:48 AM
ZoFastSS's Avatar
You'll be okay with those seals.
Old 05-29-2006, 10:58 AM
Big Budda's Avatar
so far so good with mine...
my kit came with all exhaust seals also
Old 05-30-2006, 08:55 AM
GuitsBoy's Avatar
If theyre all brown, youre fine.
