platinum spark plugs?
spark plugs...yes i've search...keke
i see most recommend or is using ngk tr55...i'm assuming it's the gp platinum...has anyone used the double platinum???
http://www.ngk.com/results_app.asp?AAIA=1358546
Originally Posted by Yellowbrother
wat's the vpower made of???
any reason to use a copper spark plug instead of platinum??? my maxima came stock with ngk platinum...and those guys only use copper when they go n2o or force induction...
That's what she said...
Yes, the price is the main reason why people use the tr-55 v-powers. You could change them out 4 times for what a set of iridiums cost. You can buy a whole set for $16. I ordered some NGK tr-55 iridiums last night from Thunder, only because I was ordering some other stuff and wanted to try them out.
They are having an everything's 10% off sale.
thunderracing.com
thunderracing.com
I went with the NGKs. Part number 3951. I just could not justify spending 8 bucks a pop on a part that I was eventually going to throw away. Gotta say the car is running quite smooth.
the ngk that came with my maxima and what i replace with are around 5 bux a pop...the ls1 is outta my car rite now with headers off and everything so i figure i'd change out the plug...but from what i've read alot of hybrids with ls1 have a big problem getting to the plugs in the back i'd figure i use the platinum so it'll last a lil longer and not have to get in there as much...
Originally Posted by taintedmeat
You have an ls1 in your Maxima? Pics?
haha...no...my maxima is my daily driver...keke...silly boi...too much work to convert fwd to rwd...i was just saying that the plat ngk for my maxima is about 5 dolla a pop...and with the difficulties that i've been reading on when the motor is in the car it's hard to get access to the rear spark plugs...i'm putting the ls1 into a z32...just got done with the mount...need to fab up the firewall and tranny tunnel...i'm changing whateva i can now while the motor is out...but if indeed it's that hard to change out the rear spark plugs i mite as well buy the plat and forget bout it for a while...
1 Post
LS1 plugs aren't that bad. Its about 30 minutes a side. Should be one of the first things you do every season if you have a lot of money in your car. In March 07 or whenever Michigan says she can come out and play next spring I'll be filling her up with Amoco Ultimate, and dropping in some new NGK's. I run 1 # colder plugs to help protect against pre - detonation. So for 1 hour and $20 you can have a new running car every season. Wires probably every 3rd season unless I don't drive much. Those headers cook the hell otta my wires. JMO
Originally Posted by JDP
i heard copper conducts better than platinum, correct me if im wrong
from a small research that i've done...it appears like of all the major conductor...only silver has better conduction property then copper..gold has less conduction property but is desireable becuz it is not prone to corrosion...and corrosion is the flaw of copper...i'm assuming y platinum cost more is due to this same property as gold that it's not prone to corrosion thus better conduction in the long run??? this is only my assumption based on what i've found so can anyone confirm this???
Originally Posted by Asmodeus
