Should I be worried? Ticking noise just started.
Old 05-28-2006, 11:14 PM
Nimitz87's Avatar
Default Should I be worried? Ticking noise just started.
k my car has SLIGHT piston slap on start up and goes away, however I just got on it pretty good on the highway, reason being i wont be driving the car for 3 months...taking a little summer vacation to Parris Island
anyway on the way home my buddy asked what ticking noise was, it increase with rpm from idle and its pretty loud, im thinking valve train? car seems to run fine...any ideas guys?
I could try and get a sound clip with my cellphone...
Chad
Old 05-29-2006, 02:37 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Might be an exhaust leak. I wouldnt jump to the worst conclusion yet.
Old 05-29-2006, 03:49 AM
Formy's Avatar
Have you recently done any plug changes on the car? Could be a loose wire or a loose plug.
Old 05-29-2006, 05:20 AM
Predator's Avatar
It's probably the crappy stock pushrods.
Old 05-29-2006, 01:06 PM
Nimitz87's Avatar
this is what im afraid of
thank goodness it happened now and I wont be needing the car for a while...this may mean Heads/Cam depending on what it is.
Chad
Old 05-29-2006, 01:25 PM
Predator's Avatar
You'll be happy you did a cam though, so it's a blessing in disguise. After installing my new cam, pushrods, and springs, the ticking went away. It's one of the best (if not THE best) mods you can do.
Old 05-29-2006, 01:48 PM
Nimitz87's Avatar
what cam did you go with? im looking at the TSP torquer v2 232/234 595'/598
Chad
Old 05-29-2006, 02:19 PM
Predator's Avatar
I went small, TR224 .563/.563 112LSA, but when I install my ported LS6 heads, I'll be using 1.8 rockers which will get my lift around .600, and PP .650 dual springs. It's all in my signature. I think the TR224 is a good compromise street cam. I've been very happy with it.
Old 05-30-2006, 08:50 AM
GuitsBoy's Avatar
pushrods are a simple and relatively cheap fix. Id be hopeing it WAS pushrods and not something like lifters.
