28x 15 Mickey Thompson ET Street
You have to run a 7-7.5 back spacing and modify the inner fenderwell where the bump stop is and in the front inner corner.A local chassis guy showed me how to do mine so I could run a 28x12.5r15 et street.
Thanks for the reply.
I have 15x10 (7.5BS) Weld Pro Stars on back right now with 26x11.5's. I want to add some gear to it but I can't without adding some tire. I was told that you had to cut the bumper cover but it doesn't look like it to me.
Originally Posted by cainsw
Will they fit without cutting or rolling the quarters and rear bumper cover? I was told they wouldn't
that tire is dimesionally similar to a 275/60/15. Only difference is overall height is 27.3" for some reason to the regular radial height of 28" .
Section width is the same as a 275/40 17 and are approx 1.6" taller overall.
I dont see them hitting the rear cover and you'd have about 1" left back there.
Edit- what size 28" ET street were you looking at? My references are for a 28x11.5/15 Et Street
