A slight problem - valve spring swap
Old 05-29-2006, 01:49 AM
sh33p4u's Avatar
Default A slight problem - valve spring swap
Yeah I was installing valve springs, and I dropped a lock somewhere in the valve cover area. I think it went in one of the head bolts holes right behind the valve springs, you know the really deep ones. I stuck a screw driver in there and it goes forever!! haha. Well I just wanna ask if anyone knows where this hole goes? Does it go to the oil pan or what? Thanks in advance!!
Old 05-29-2006, 02:11 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
It is probably lodged in an oil passage in the block now.
Old 05-29-2006, 06:50 AM
vettenuts's Avatar
Those holes go to the lifters. Look down the pushrod holes with a strong light.
Old 05-29-2006, 10:35 AM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
pull the pushrod and try fishing it with a thin pen magnet.
Old 05-29-2006, 12:18 PM
sh33p4u's Avatar
I'll give that a try, any more help out there? I really appreciate it, thanks.
Old 05-29-2006, 01:13 PM
Moderator
davered00ss's Avatar
Small pen magnet, or pull the heads.
Old 05-29-2006, 01:44 PM
sh33p4u's Avatar
I must be lucky, the pen magnet thing worked. I fished around for like 15 minutes then all of a sudden *click*. I pulled it out slowly and there it was! What a relief that is... thanks for the help guys!
Old 05-29-2006, 02:21 PM
Predator's Avatar
Thumbs up
That must feel good!!
Old 05-29-2006, 02:31 PM
Gearhead1's Avatar
Lucky Bastard!! Nice save!!
Old 05-30-2006, 01:18 PM
radkon's Avatar
We did the same thing on a buddy's cam swap but had to pull the head to get the damn thing out. Now we stuff the head bolt holes with paper towels before removing any parts of the valvetrain.
Old 05-30-2006, 02:23 PM
vettenuts's Avatar
Stuff rags in all the holes before continuing, at least if you drop it it won't go in the motor.
