Initial Startup/Dyno of My Twin T-67's
Initial Startup/Dyno of My Twin T-67's// Another update
I wasn't going to post this until everything was perfect with the SS. BUT I couldn't wait. I am very pleased with initial numbers.
This a small clip of my 98SS's startup.
Also below, is its initial dyno. Just started the pull when an oil leak was discovered and the run was shut down at 5700 rpm's. This was on waste gates only. 8lbs of boost. Timing was at 17 degrees. Engine is a built 408, T-400, 12-bolt Mosier, 3:73 gears, 30x10.5x15 Hoosiers, 116 Blue gas, intercooler was NOT used. Oil leak has been fixed, and tuning will continue next week. Should be able to get 700rwhp on the waste gate's 8lbs. Goal: 1000rwhp
On schedule to make our first voyage to the track Sunday, June 4th (local vet track rental day).
623rwhp; 5,700rpm; 11.8 A/F
Video of Initial Startup
http://sio.midco.net/davidb/InitialStartup.wmv
David
David
Originally Posted by KAOS
that is nuts. so why didnt you use the intercooler? and that is an awesome looking power curve. what was the tq on that thing. all i can say is wow
Intercooler wasn't use because it was its initial pull and don't believe Joey realized it was going to be that big, that fast.
No tq numbers were run.
We'll post some more dyno sheets as the tuning progresses.
David
Originally Posted by bad95killer
Impressive intial numbers buddy w/o using IC. keep us updated .peace
to ur 98SS
Intercooler did not have any water in it because i was only getting air temps around ambient.. will use it when i am actually doing some real pulls as this is only the sixth pull from startup... This is on a Aem ems. i cant wait til i put some boost to this. anybody notice it run out of gas idling at the end of the video? oops haha
