How much taller are Morel lifters?
Originally Posted by Moparnos (The SLP Guy)
use a pushrod checker to accuratly measure for them. but i believe the morels are .030 taller.
Now if only I could find a place that has the Morel lifters in stock.....
Originally Posted by JakeFusion™
Plunger depth is the same, but that doesn't matter. The Morels need only .030" preload as opposed to .100" of stock. So the Pushrods will need to be .070" shorter.
Originally Posted by Cstraub
Thunder should have lifters today or tomorrow.
On paper, with Comp OE lifters, I would have tried 7.40". I guess it would be ~7.10" with the Morels. That doesn't sound like an off-the-shelf pushrod to me. I'm such a newb with this stuff
Originally Posted by ShevrolayZ28
Cool! But now I have some more figuring to do....
Originally Posted by vettenuts
Not really because your preload will also be different. The lifters will require a shorter pushrod due to their length and then shorter still due to the reduced preload. Best to buy an adjustable pushrod from Thunder when you order the Morels ($20) and measure. It only takes a few minutes and that way you will only order the pushrods once. I did this as one of the first things and the pushrods were at my house before I even needed them.
That was helpful. I'll do it that way; I'll order the pushrod checker, then order the correct length pushrods.
I was going to make a ball park guess and order them at the same time as the other stuff. I'd most likely have guessed wrong and ended up with an extra set. (Especially since I seem to be unable to do simple math.)
Viper, thanks for pointing that out! And I'll keep you in mind if I end up needing 7.325".
