ETP 215s or AFR 205s
Originally Posted by c5_ls1_6spd
which head flows better and which would you choose? why?
The ET's are awesome if you want to spend a few hundred more including the rocker stands. They are an 11* vs AFR's 15* head so you will get slightly better flow characteristics and more PVC. Plus the bigger runner might be better if you plan on a good size cam.
I went the AFR route, mild cam and milled heads. You will be happy either way. The ET's are awesome though.
ETP are super sweet and make a ton of power.
ETP Cons
Valve Cover Spacers
New Pushrods
On my corvette you have to swing the alternator out
Fuel Rail covers don't fit(corvette)
AFR's are true bolt-on's. You can use the stock pushrods, valve covers, fuel rail covers. And you know how much power your going to make.
AFR cons make a lil less horsepower then ETP's, should mill, maybe lose 20rwhp at most.
ETP Cons
Valve Cover Spacers
New Pushrods
ETP Cons
Valve Cover Spacers
New Pushrods
ETP Cons
Valve Cover Spacers
New Pushrods
New pushrods most likely will be required with any head, especially a head that has some milling.
what do you mean when you say, "should mill, maybe lose 20rwhp at most"?
Originally Posted by Fireball
Valve cover spacers haven't been required since the redesign in February. My OEM unmodified valvecovers fit ET 225s just fine
did your fuel rail covers fit?
whys that?
If you want to run a bigger cam and not fly-cut, go with the etp's. If you need a carb # and don't want to wait too long, go with the afr's. Both good choices.
