Valve Stem Seals Are Different?
i am doing head work which is a pretty normal thing and i plan to have them hot tanked after that is done... now i ordered new valve stem seals and just after i got them i realized they were different from what were on the heads originally. the original seals bend out on the bottom that look something like a bell. the new ones i have just go straight down without the flat edge on the bottom. everything is the same size but i just need to know if they are the correct seals or not... any help would be good.. thanks alot
I think 02's had the seats and seals as one piece, you will need to buy new seats for the seals to go on.
reference http://www.ls1howto.com/index.php?article=23
read the 2nd paragraph on Part 3
