Is it just me or is the year 2000 notoriously bad about burning oil??
Just curious mine uses the standard for ls1s and thats about 1 qt every 1000-1500 miles but i have friends with 98s and 01s and 02s that say they dont use any oil yet all my friends with the year 2000 say theirs uses oil just curious?
ЯєŧąяĐ Єl¡m¡иąŧøя ™
My 2000 Z28 consumed 1 quart within 800 miles when new while the engine was breaking in. It has not burned any significant amount since. Maybe just under 1/2 a quart every 4000 miles and I drive her pretty hard.
You guys may want to consider trying a thicker oil. The LS1 really likes a true 30 weight oil at temperature. Some 5W-30 oils are closer to a 20 weight at temperature then a 30 weight. I too had an oil consumption problem. Got a catch can and that stopped dumping oil into the manifold but then I started reading here and over at bobstheoilguy.com based on Patman's advice and I switched oils from M1 5w-30 to German Castrol 0w-30 and my consumption problem stopped. I also stopped getting much oil in my catch can. I'm not saying this will be the same for everyone but it seemed to work for me.
Before switching oils I would burn 1 qt. every 2k miles or so. the GC also seems to have tamed the "sewing machine" sound my engine used to make. I'm not a big believer in miracle treatments but I'm sold on the GC stuff for sure. It might be worth a try.
There are tons of posts on the GC over in the maintenance section or check out the above mentioned site. I also suggest that everyone get's their oil analyzed at the next oil change interval. It's only 20 bucks and gives you a good idea of what your oil is doing to your engine. Blackstone labs is who I use. I don't want to post a link as they are a non sponsor but they are easy enough to find using Google.
1 Post
I use about 1/2 to 1 qt before I change the oil. Sometimes I change at 3000 other times I change at 5000 miles. It all depends on how hard I run, and I keep an eye on my oil life monitor system. At 3k I am sometimes down 1/2 a qt, and at 5k I have been down 1 full qt. That was doing a lot of hard driving though.
