Pix of ground calipers.......for Pro-stars 99' Z28
Hope these are good enuf.
The red paint is after. Sprayed it over and over to judge the spot where it touched.
I took the tires off/on over 5 times each
Forgot a damn impact too.
Notice the bad *** Moser symbol
15x8 rear 26in tire
used small spacer
Stock.......
15x8 rear 26in tire
used small spacer
Stock.......
I wouldn't run a spacer in the rear, if you grind enough, you'll be fine. What do you need an impact socket for? Just get a regular deep well with a torque wrench and you're set.
takes over a jillion turnes per nut.
I would have an air tool to do it again.
I have a moser rear. the studs are long as hell.
i ground alot and thought it was enuf. still did not clear.
after the untimely brake failure of a fellow Ls1'r. I thought the spacer was safe.
Matt, local guy in Midwest. there is a post there.
Never finailized the fact that it could have been the caliper.
All we know is the caliper split apart while braking from 130.
I though I ground alot. Its prettt intimidating taking all that metal off.
I should keep going as I am sure I will have 28/10's next year.
Originally Posted by INMY01TA
I read that post and am a little confused by it. Apparently it was his front caliper that failed. Most on here dont grind the front calipers.
I had to do the fronts a little.
the pix are the rear though since it was alot more taken off
my back calipers are ground way more. Almost makes me uncomfortable. This is w/ a 15x10 prostar and no spacer. I also heard about the caliper failure in the midwest section. Granted my front calipers are hardly ground, but the backs worry me.
15x8 rear 26in tire
used small spacer
Stock.......
15x8 rear 26in tire
used small spacer
Stock.......
