What offset tucks in the wheels the best?
what offset will get rid of that 4x4 look? Especially with 17x11's?
I ask, because I just bought some rims, and Im not quite happy with how they look. What offset are you all buying? If you could post a pic that would AWESOME. Thanks
Offset will only change the look in the cross-car direction (side to side). There is a sticky at the top that will show you how different offsets will sit.
https://ls1tech.com/forums/wheels-tires/346147-wheel-sizing-chart.html
If you don't like your 4x4 look a.k.a. car looks too tall, you need to look into lowering springs. Just be prepared for some mods to make the wide tires fit in the rear once it is lowered (adj panhard rod, BFH, roll fender). Do a search, there is tons of info on the board for this.
