Any of you guys runing Custom Fuel Rails?
Re: Any of you guys runing Custom Fuel Rails?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LS1 BU:
<strong> I'm running the speed inc. rails also. They are nice pieces. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">How are they hooked up. Did you leave all the otehr stock lines in place, or did you do everything from tank to injectors. Also are you running an external fuel pump. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
I have modified stock fuel rails on my car. There are -6AN fittings brazed on to the ends of each rail, which are now used for the inlets. The pulse damper is gutted, and the stock inlet line also has a -6AN fitting brazed on to it and is now the return line which goes to my Aeromotive regulator then back to the tank.
I don't think the stock lines are an actual restriction until you're putting down some really big HP numbers. If you aren't in to modding stuff yourself, the Speed Inc. rails are really nice.
Super Moderator
Smae thing as George....stock rails with crossover removed and -6AN fittings silver soldered on all ends:
www.cofba.org/users/reckless/fuel.html
