Hairspray??
6 Second Club Moderator
Originally Posted by Rusted40
anything you guys use to keep the cold side hoses on?
just short of weatherstrip adhesive at least...
I have been told hairspray works well
It use to work pretty good on the hand grips racing motocross????
I cannot tell a lie
the pipe in question does not have a bead
guess I'll weld some on first...
the hairspray I can borrow from my sister if she uses it
thanks for the input guys
SSU Moderator
Originally Posted by MrDude_1
if not, you can barrow some from most thirdgen owners..
Use high-quality dual-density silicone couplers and weld a bead around the pipe and you won't have a problem, even with cheap hardware-store stainless hose clamps. I've been over 24 psi like that with no problems.
Mike
Mike
ya t-bolt clamps and silicone couplers are the only way to go
I welded beads on the offending pipe and so far so good
before the pipes were blowing off at 22psi
