Anyone have a problem with Dipstick popping up under hard acceleration??
Old 06-01-2006, 11:04 AM
allngn_c5's Avatar
Default Anyone have a problem with Dipstick popping up under hard acceleration??
After finishing my car, I noticed that my oil dipstick would pop up if I was shifting in the 6500 RPM range. I checked my emissions crap, and there weren't any issues. I contacted GM and made a claim. They sent the dealership a new dipstick with a new O-ring gasket. This has since cured the problem. I am glad I don't have too much crankcase pressure. That would've required more effort to fix. Please chime in if this has happend to you, or you have heard of it. Will I have this problem again if my O-ring on the dipstick wears out?? All opinions welcome. What corrective measure would you suggest if it starts happening again?
Old 06-01-2006, 11:38 AM
GuitsBoy's Avatar
Usually the dipstick blowing out is indicative of high crankcase pressure either from a cloged PCV line or worse from a cracked ringland or worn piston rings.
Old 06-01-2006, 12:29 PM
allngn_c5's Avatar
I checked the pcv lines and no issue there. As I said in the post, I called GM and without question they sent me a new dipstick. They claim to have had several claims of dipstick O-rings not maintaining the dipsticks position due to failure of the O-ring. I had this fixed 4 wks ago and haven't had any issues. Plenty of high speed driving, and quite a few high rpm shifts. I appreciate you comment. I am glad it was the O-ring and not what you were talking about.
Old 06-01-2006, 12:34 PM
Studytime's Avatar
I would still be leary that it was excess crank pressure. Have you done a compression test recently? If nothing else, it will verify that the dip-stick assembly was defective.
Ben T.
Old 06-01-2006, 12:55 PM
allngn_c5's Avatar
Compression was checked @ D&D motorsports 10.9 to 11.1 to 1 was the compression range from the cylinders. I had 1 cylinder at 11.1 and 1 at 10.9 the rest were at 11.0 to 1
I am convinced it was just the O-ring being fatigued over the course of 6 years, and now dealing with all the extra heat, and higher compression. If I get any more issues with the dipstick popping out I'll have it looked at.
Old 06-01-2006, 01:21 PM
Studytime's Avatar
Hmmm... apparently they used atmospheric pressure to convert the pressure readings to a ratio? I'm not really sure what they did. Can someone else chime in?
Usually a somewhat arbitrary number is collected and you're checking for relative deviation to that number- not looking for a set magnitude or ratio.
I'm not sure if the shop was attempting to put their information in simpleton's terms, but if I had to guess I would venture to say so, and I would do my own compression test again.
If I'm wrong someone educate me to the 'new' way.
Ben T.
Old 06-01-2006, 01:30 PM
allngn_c5's Avatar
Are you saying I should go back and get more info?
I hope I didn't get bs'd.
Old 06-01-2006, 01:39 PM
GuitsBoy's Avatar
Usually youll get numbers ranging in the 180 to 220 psi area. The number you get is not so important as that theyre all fairly uniform. I dont think theres any way to convert to your calculated compression ratio which is usually 10:1 to 11:1 for a n/a motor.
Old 06-01-2006, 01:43 PM
allngn_c5's Avatar
I am going to go by the shop. Maybe they did use laymens terms for me. After reading this I want them to explain it further. Thanks for the insight.
Old 06-01-2006, 02:06 PM
Studytime's Avatar
Good luck. I'm sure you'll get it. Ask them to see the gauge that they used, and ask them where 11:1 is on it.
Just kidding. I'd go over and be completely cool about it. Just tell them you're trying to learn. I'm sure they will be helpful. Good luck.
Ben T.
Old 06-02-2006, 02:06 AM
eallanboggs's Avatar
The compression ratio should be the is on all cylinders. That value assumes all the engine parts are in good condition. A compression test is done to verify whether or not top end engine parts are worn especially on a high mileage vehicle. Normal wear and tear doesn't change your compression ratio, but it can reduce compression. I didn't know there was such a thing as a compression ratio gauge. Where do you buy them? I guess I'll have to look on E Bay just like you have to do for all the hard to find items. I'll bet they're expensive.
Old 06-02-2006, 08:08 AM
IT P.S.I.'s Avatar
honestly, i would get a leak down test!! i have seen a few motors with good compression and not so good leak down!!
frank
