Am I being held back severely or just alittle?
I have had my HPE 408 installed for a little while now(w/ pacesetter LT's, exhaust, highflow airlid, ported TB.) . I know i am being held back by having stock heads(cant affrod new ones yet) but im also worried if i am being severely held back by running the stock intake manifold and stock MAF. is it imperative that i upgrade ASAP? or will i be ok waiting til end of summer when i have the funds available.
if you know of any good deals on MAF and Intake Manifold..let me know
if you have the ls1 intake instead of the ls6 and stock heads as well you are very restricted.what cam are you running ? you will be amazed when you put a set of good heads and a 90/90 on there !
im running the am HPE builds and put in the crate 408 motor. 238/242 115 lob seperation 610 lift. and by 90/90 u mean 90mm MAF and 90mm intake manifold i assume. i see u have that in your info. what price did u pay for both im looking for a deal.
90/90 meaning 90mm intake manifold and 90mm throttle body
1 Post
That LS1 intake is horrible. Upgrade for sure. LS6 or FAST. I am only running a 78 mm FAST w/78mm ported TB, and check out the #'s I am putting down. Your 408 is exactly where I'll be heading in a couple years, but I'll be supercharging mine. Good luck, hope everything works out. AFR heads if you can afford them.
i do have a ported TB already i forgot to mention that. but what about the MAF should i replace that too? and i will get a 90 mm intake manifold(what else will i need to replace?) heads will come later when i have the funds available. what kind of increases in rwhp will i get from just the manifold and maf upgrade?
Patriot Stage 3 LS6 "style" heads are around $1475
and LS6 intake can be found for $200 if you shop around (used)
MAF not needed at this stage.
What year is your car?
if you want optimal performance, then yes, get the 90/90 setup, if not, then the ls6 will be fine. regardless, you need an intake. Yes you will have to get a new lid if you go with the 85mm maf. You can sell yours to offset the cost of the new one. With that cam and motor the heads are also something you need to invest in. A 225cc would be best, but not a must. It all depends on what you got to spend. If your happy with it as it, then stick with it.
Nino
Nino
what if i remove the MAF which someone mentioned above. then can i use the airlid i have? and right now i have ported TB if thats 78mm do i need to get 90mm to fit the 90mm intake manifold?
what if i remove the MAF which someone mentioned above. funny u bring that up. It was not too long ago that Speed Density (no maf) was the way to go. A few tuners in the pcm section that have gone back to the maf and didnt notice a difference, so I suggest staying with it for now.
then can i use the airlid i have? and right now i have ported TB if thats 78mm? If you want to keep the airlid you have, then keep the maf, go with a ls6 intake and keep your current TB. Use the change/difference to put towards a set of heads.. that would be my suggestion.
do i need to get 90mm to fit the 90mm intake manifold? yes
ok sounds good so if i keep the maf and ported TB go with ls6 intake and a set of heads im lookin at a good 50 rwhp gain. and if i did the 85mm lid and maf along with 90/90mm im lookin at what 65-75 rwhp gain? plus another 1000$
