firepwr
06-02-2006, 05:39 PM
Hi guys,
I'm running the nasty tank in my car and I'm having a couple of problems with it. The custom sending unit is not reading correctly. When I'm on E and I go to fill up it only takes 6 gallons to top off. The second issue i'm having is venting the tank. I'm running a piece of -6 up to a vented filter in the fender above the filler neck. I had a one way rollover valve in line before the vented filter but with the valve it would take me days to fill up. Since I took the valve out I can fill up fine but when I take a sharp turn the gas sloshes out the breather. I'm thinking of finding a filler neck from another car that has a small line that comes up parallel to the main filler and ties into the filler neck so it will vent better and still be sealed up when I put the gas cap on and put the rollover valve back in line. I just want to get your ideas on how you did yours and how your sending units are reading.
Thanks again,
Adam
Thanks again,
Adam
