headers gaskets and bolts
I plan on using the bolts that come with the Headers. As far as Gaskets go, I haven't had a problem with the ones that come with most Headers. I use a good amount of high-temp Copper Sealant, I pretty much paint the Gasket with it and let it sit for a while, then run it through 3 heat cycles. I haven't has any leaks. I wouldn't use them little paper ones on where the collectors bolt, they fall apart.
