TR CHEATR vs TSP 224R on a 116 LSA
Old 06-02-2006, 10:54 PM
2002BLKWS6's Avatar
Question TR CHEATR vs TSP 224R on a 116 LSA
Hey,
I'm not the best when it comes to understanding internals...so any feedback is greatly appreciated.
I've had the Cheatr cam for a while, but i haven't installed it yet b/c I've been saving up for a set of heads. Anyway, I was looking at TSP 224R with a 116 LSA and was wondering how different this cams performance would be from the Cheatr. Where would the power under the curve fall for each? The main reason I got the Cheatr is b/c i knew it would be quiet and made decent power for a "small" cam. I'm sure the TSP will give me a slightly longer valve spring life but probably not by much. Is there enough difference between the two for me to even consider making a switch?
Cam Specs are:
TR Cheatr - 216/231 .604/.589 116 LSA (my actual specs)
TSP 224R - 224/224 .581/.581 116 LSA
Other mods are listed below.
Thanks!!!
Old 06-02-2006, 11:26 PM
Grimes's Avatar
I would just try the cheatr cam you have now.
Old 06-03-2006, 12:40 AM
PREDATOR-Z's Avatar
The 224R under a proper combination will make more power due to more duration.
Both are higher reving cams.
Their main attribute is Stealth (little lope)
Old 06-03-2006, 05:03 AM
tb109's Avatar
Old 06-03-2006, 05:11 AM
PREDATOR-Z's Avatar
Old 06-03-2006, 05:13 AM
ShevrolayZ28's Avatar
Is there an echo in here?
Old 06-03-2006, 06:03 AM
Street Lethal's Avatar
Old 06-03-2006, 07:15 AM
Slow00ls1T/a's Avatar
Is there an echo here?
Didnt patrick make some good numbers with this cam
