Starter Problem?
Old 06-03-2006, 03:29 AM
4ced's Avatar
Default Starter Problem?
When starting the car from cold the car starts right away, but if the engine is warm and i switch it off, whenever i switch on the engine takes a few seconds to turn...
any idea if this is a sign of a failing starter or something else? perhaps the battery (although the battery seems fine)
Old 06-03-2006, 06:56 AM
Farmer2's Avatar
It sounds like the starter to me.
When it does it next time hold the key in the start position and have a friend tap the starter with a blunt tool and if it starts I would say starter. If this works it normally is the solinoid on the sarter that gets arcing marks on the disk that cause a bad connection.
It could be alot of things but the way this sounds I would have the starter tested.
