1998 LS1 #806 heads on a iron 6.0 block??
Old 06-03-2006, 09:31 PM
GTA91's Avatar
Default 1998 LS1 #806 heads on a iron 6.0 block??
I've been told by numerous people that when running the 806 perimeter bolt heads that you have to run stock gaskets due to a little "notch" on the underneath of the head. Running any other head gaskets ('99-later or cometics, etc) would cause a leak. Anyways, so my question is can you run these 806 heads on a iron 6.0 block and use stock '98 head gaskets?? I'm not sure if you could or not since the difference in bore size. Any help?
thanks!
-Jeremy
Old 06-04-2006, 02:41 PM
GTA91's Avatar
No one???
Old 06-04-2006, 03:37 PM
Zick's Avatar
Well the problem I see with running stock 98' head gaskets is the the bore size is going to be too small.
I'd image somebody out there makes something that will work but I don't know who. Sorry.
Old 06-04-2006, 09:16 PM
GTA91's Avatar
Anyone else? I guess I'll have to call some sponsors tomorrow... I really want to keep these heads.
Old 06-04-2006, 09:44 PM
ThaLS1KidII's Avatar
If you are running any head on a 6.0 you have to use the 6.0 gasket because of the bore size. The 5.7 head gaskets will hang over into the combustion area if you use them on a 6.0.
Old 06-05-2006, 01:08 PM
GTA91's Avatar
Yeah, that's what I thought... like I said, I don't think you can run 806's on a 6.0 then...
Old 02-13-2007, 08:42 PM
The stunningman's Avatar
Anyone want to answer what type of gaskets can be used?
Old 02-13-2007, 09:12 PM
GTA91's Avatar
I never found anything out. I went with 317 truck heads instead that were stage 3 with 2.08's
Old 02-14-2007, 07:16 AM
Yeah but I know people have done it I have saw it listed before in some sigs. The 5.7 head gasket is way to small. All I feel you need is a single layer or composite type gasket.
Anyone with any help on this will be greatly appreciated.
Old 02-16-2007, 12:35 PM
NVM stock 6.0 MLS gaskets seal fine.
Old 02-16-2007, 03:16 PM
justin b's Avatar
the ls1 heads have a smaller bore size and would hurt the 6.0 perfprmance,not to mention a smaller runner,317 heads worked a better choice
Old 02-16-2007, 05:20 PM
1999ssls1's Avatar
I have 853s with felpro 6.0 head gaskets
Quick Reply: 1998 LS1 #806 heads on a iron 6.0 block??
