PCV system
I have read the install instructions for the LS1 to LS6 PCV swap, its stated that the 'old style' LS1 blocks need to be dremeled.
So I assume this means later LS1 blocks, like 2002+ are designed with enough clearance for the LS6 valley cover.
My million dollar question is:
How can I tell if my block is going to need to be modified/dremeled or not - before having to remove my intake/original cover?
Originally Posted by Brian2001SS
Not if you are looking to clean the engine bay up. Just my .02. But if your looking for less oil consumption, then your right on target.
$150 for the kit from TR is fine by me, heck, I could even do the install, short of cutting the block. That part bothers me!
Maybe a winter project this year.
Originally Posted by DAVESS02
I've got an 02 SS and mine has the part that needs dremeled. On a side note, it does have the holes drilled and tapped for a chain dampner. My guess is that only LS6 blocks dont need modded. THATS JUST A GUESS. If you check the casting number then you'll know.
