are stage 3 heads to much for stock cube?
i have a 235/ 240 601 /599 on 112 tsp cam and an ls6 intake and was wondering if some stage 3 heads would be too much and what would be the difference if i put them on
and i was also thinking ofgoing with a fast intake and a 90mm tb ported to match the heads
Stage 3 heads usaully incorperate the same port as the Stage 2's, but with a larger bore opening and bigger valves.(2.08/1.60) For a stock bore motor, these addition aren't bennificial, and somewhat hurtful. To much valve shrouds the chamber, or better yet, the valve is to close to the cylinder wall when opening to let the air disburse evenly. In most cases, 2.05 is the biggest intake valve you want in a max effort stock short block.
Is there a universal decoder ring for all this Stage 1, 2, 3, 4, 5, 6,000,000 crap? Let me get my rice bowl out...
Andrew
Andrew
Originally Posted by mushroom281
wilkl stage 2 heads be enough for a small stroker whenever my stocker blows
maybe a 383
maybe a 383
Originally Posted by Beast96Z
Well, for the average joe that dosen't know anything about heads, they have to have something to go by. I prefer to look at the runner volume and valve sizes to base a "Stage".
The bottom line is that you need to look at your application and choose what heads will work best for you regardless of what "stage" it is.
Andrew
Flossin' twin turbos
Exactly my point. There is no universal standard for "Stages". Its comical when people start comparing "stages x" heads from company ABC to company XYZ.
Andrew
Andrew
