More progress pics 3
Exhaust mockup is done, we notched to passenger floorpan for the Mufflex to fit UP in the car, you cant see any exhaust from the side or rear of the car. The cross brace on the drivers side that the Hedman 1 7/8 race 3.5 inch header collector was made to point down to clear, we notched it up even with the floorpan so the 3.5 inch y pipe will not hang down, we heated and bent both header collectors up parallel with the ground, the y pipe and collectors are actually higher than the transmission pan. Alot of work but it looks cool.
3.5 inch Y pipe
4 inch Mufflex fit up in the car, nothing hangs out
Notched floor so collector can move up close to floorboard
I know all the clamps are out of whak, this is just a mockup/fit deal.
She coming along..........
David
3.5 inch Y pipe
David
Looks like everything is coming together good.
As a side note it'd help if you rescale the pictures I have a High Speed connection and it took a little longer to load the pic's, so it won't be so bad on the dial up users.
